Wireframe options
| Command | Path |
| Wireframe Options | View > Rendering |
A wireframe render uses lines to represent the edges of objects. Planar objects with solid fills are drawn in stacking order. In a 3D wireframe view, objects may overlap, obscuring objects lower in the stacking order. The wireframe options control whether fills should be visible for planar objects in 3D views, and if they are visible, sets the fill opacity of filled planar objects.
To set wireframe options:
Select the command.
The Wireframe Options dialog box opens; set the parameters.
| Parameter | Description |
| Show fills in planar objects in 3D views | Displays fills for 2D planar objects in 3D views |
| Fill opacity | Sets the opacity of filled 2D planar objects for situations where objects overlap |
